Message 1 of 17
delete?
How do i delete calls from
BT XD56    with answer phone (cordless)
16 REPLIES 16
Message 2 of 17
Re: delete?
Message 3 of 17
Re: delete?
I have but I cant find where it explains.... also it only rings once when someone is calling?
Message 4 of 17
Re: delete?
Page 31 of the manual tells you how to delete calls.
Message 5 of 17
Re: delete?
ok found the page thanks but it says  unavailable when i click on the number i want to delete, also,how do i change it to ring more than once if someone is ringing me?
Message 6 of 17
Re: delete?
Hmm.  Have you tried the helpline 0800 218 2182?
RIC9380
Anonymous
Not applicable
Message 7 of 17
Re: delete?
What exactly are you trying to delete?
Message 8 of 17
Re: delete?
just calls that i have had
Message 9 of 17
Re: delete?
They tried to help
Anonymous
Not applicable
Message 10 of 17
Re: delete?
When you press the Calls/Volume Up button I would expect some options to appear on the display, activated by Menu &/or Mute buttons. Somewhere in there should be an option to clear the whole list.
No idea if that's connected with the ringing issue, but there have been reported instances of odd behaviour with BT phones when that list becomes full.
