hellothere19
Message 11 of 16
Re: faulty line /house alarm not working
I don't know, I know it certainly is not my fault, as I haven't touched the panel
I pay for a monitored alarm which includes Redcare, so they need to sort it out between them but I feel it might take a while....
hellothere19
Message 12 of 16
there is a test socket i have access too, but I don't have an old fasioned wired phone I can use to test from here
Keith_Beddoe
Message 13 of 16
You do not need a phone, simply remove the front part of the master phone socket, to reveal the test socket, that should isolate the alarm unit from the line. Then ring the phone number for that line, from a mobile phone, and see if it rings out, or is still busy.
If its still busy, its a line fault. If it rings out, then its the alarm unit causing the fault. I am surprised that they did not ask you to try that.
hellothere19
Message 14 of 16
thanks for the tip
I spoke to ADT again, who told me it was a redcare/BT issue. I used the tet socket and it sounded  busy so it was definitely a line fault
The line has now been restored by BT, just wish it would have been dealt with quicker.
Keith_Beddoe
Message 15 of 16
thanks for the tip
It would depend on what SLA you have with BT.
https://btbusiness.custhelp.com/app/answers/detail/a_id/11758/~/what-levels-of-support-do-bt-offer-f...
These are for business lines, but they may also be available to residential users who have a Redcare agreement. Not sure about the extra monthly cost.
See https://www.bt.com/pricing/current/Maintenance_boo/0201_d0e5.htm#0201-d0e5
"Where BT provides telecommunication service or hires equipment to Residential customers, Standard Fault Repair service (Standard Care) is included in the rental. Prompt & Total Care are also available for telephone service and/or equipment at the charges shown. Customers with privately owned equipment may also arrange for BT to provide Standard, Prompt or Total Care maintenance"
So it looks like it is available.
Devon_Dave
Distinguished Guru
Message 16 of 16
With redcare the connection to the alarm unit is wired direct onto the back of the linebox so it's not possible to isolate it by removing the front plate
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
