Message 1 of 9
faulty line
trying to report a faulty line for an 80 year old, but problems with call centre wanting details from me relevent to my family or won't report. They want my mothers maiden name and date of birth even though they are deceased and im an aop as well.
8 REPLIES 8
Message 2 of 9
Re: faulty line
They are questions that the account holder are asked in order to verify that the Customer Service rep is dealing with the account holder.
If you are not the account holder you will need to tell the CS rep that and the account holder will need to inform the CS rep that it is OK for you to act on his/her behalf.
Message 3 of 9
Re: faulty line
Told the bt rep that, also that they had no money on mobile(£149 lost on waiting yesterday). Rep said no way around it .
Whole issue seemed stupid as BT would know it was their number and a fault on line. Told them persons age and ill with lung issues. What does it take to do a good samaritan report these days. Gave them her mobile but rep said they can't ring her.
Message 4 of 9
Re: faulty line
@vincent52
You said aop, do you mean POA (Power Of Attorney)?
If the POA is registered with BT, then the Service Rep should see your name against the customer account, and allow you to raise a report.
Message 5 of 9
Re: faulty line
You can report !ine faulty phoning 0800800151 from mobile free.
But for security you need account holder to start call and give you authority to deal with it
Message 6 of 9
Re: faulty line
Sorry
OAP old age pensioner. ☹️
Message 7 of 9
Re: faulty line
Was a customer, changed this year, not surprising!.......Also told rep that as well.
Message 8 of 9
Re: faulty line
Hi @vincent52 it sounds like the advisor was asking to add your details to the account as a contact so they could speak to you about your friend's line and report the fault. To do that we need some information that we can use as security questions to validate you for any future contacts you may need to have with BT on your friend's behalf. This is a BT policy as we need to know who we're speaking to in order to protect our customer's private data.
I'll send you a private message so you can get in touch with the moderation team so you can pass over your friend's information and we'll be happy to help.
Neil
Message 9 of 9
Re: faulty line
Hi @vincent52 ,
Thanks for sending over the details. I've just spoken with your aunt and she has confirmed the engineer has resolved the problem.
Cheers
David
