Message 1 of 4
handset only works on loudspeaker mode
I have just had fibre-optic cable installed in my house by Openreach and the internet is working very well. In addition I opted for Digital Voice and ordered two new DV handsets. The first handset I paired with my router (a BT Home-Hub-2) and that has called itself Handset 1 automatically, and it seems to be working alright.
Then I paired the second handset and it called itself Handset 2 automatically. If I press the green Talk button and dial a number the other person can hear me but I cannot hear them until I press the Talk button a second time to switch on the loudspeaker. Similarly, if another person calls me the phone rings but if I press the green Talk button once, while the caller can hear me, I cannot hear the caller until I press the loudspeaker button.
I give below the specification of the handset from the Settings>Product info>Handset menu.
Handset Firmware: X42_XXH30241
Eeprom: 01.00
Hardware: X42_XX_HW0.2
My guess is that there is a fault with the handset which therefore should be replaced. Any comments would be most welcome.
Thank you.
3 REPLIES 3
Message 2 of 4
Re: handset only works on loudspeaker mode
Hi @NigelBlakey
It does sound like the device may be faulty. Please give Customer Service a call where the technical team will be able to run a quick diagnostics and order a replacement if needed.
Before you do that, it may be worth resetting the handset and re-pair it first.
Ali
Message 3 of 4
Hi Ali,
Thanks for our reply. I reset the handset and repaired it to the hub. There was no change so I phoned the really helpful people at BT and they have already posted a new handset for me to try. If that is OK I have to send the faulty one back to them.
Can I put in a word for the help desk people at BT? They are really good!
Message 4 of 4
That's great news @NigelBlakey
Glad you're sorted with a replacement handset.
It would be great if you could leave them a review on our Trust Pilot page
Ali
