Message 1 of 2
landline phone question
Hello I have recently moved home, this means that i currently have no provider. Would it be possible for me to connect to BT while keeping the old number that i had in the old house?
Thank you for reading
1 REPLY 1
Message 2 of 2
Re: landline phone question
It would not possible unless you were doing a home move as a BT customer, and you were staying within the same exchange locality.
Your old number would also need to be owned by BT Retail.
A new BT order would automatically be giver a new number, assuming you did not opt for a broadband only connection, which is now possible. In which case you would have no phone number.
