Message 1 of 6
2.4 gh on smart hub 2
Folks,
I have new security camera that works in 2.4gh. How do I get my router to change to 2.4 or get it to pick up the camera and connect to network?
Thanks in anticipation
Jed
5 REPLIES 5
Message 2 of 6
Re: 2.4 gh on smart hub 2
Your router transmits on both 5Ghz and 2.4Ghz. Some devices for inexplicable reasons can't seem to cope with both bands having the same SSID (network name) temporarily disable the 5Ghz signal until the camera has connected and then re-enable it.
Message 3 of 6
Thanks, will try that
Message 4 of 6
Now working, thank you
Message 5 of 6
Mate, I'm a dunce at this.
How do I get back to the WiFi admin page I managed to switch off 5gh?
I've got no idea how I got there in the first place🙁
Message 6 of 6
Advanced settings > wireless
