Good morning
So I might be moving house soon and the place currently has a BT smart hub set up but it’s shared between a church and the house. Is it possible to have a BT smart hub set up with one SSID, but then Ethernet another one to the router with a separate SSID, therefore having separate networks for the 2?
My thinking is for security reasons and the church Wi-fi pass word will be more readily available
Cheers
It would be simpler to just replace the BT smart hub with a third party router that supports guest networks.
