CyanideX
Newbie
Message 1 of 3
2nd Home Hub 6 rebooting...
Good eveing,
frustrated as always, my first Hub 6 was contsatntly rebooting, didnt check the logs just got BT to send a second one out, and after 3 months the 2nd one is doing the same...
Firmware version:
SG4B10002244
everything was fine when I noticed my skyQ box has stoped working, went to reconnect and noticed that the Hub was rebooting.
logs show loads of TR69s
can anyone help, can I buy anything better that will actually work?  output is only from TR69s can rgrab anything else if need be.
17:59:48, 20 May.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
17:59:47, 20 May.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
17:59:47, 20 May.
InformResponse:TR69 receiving 0! 'iДx:ֳ5KFls message
17:59:46, 20 May.
ppp1:TR69 event found : 4 VALUE CHANGE
17:59:46, 20 May.
ppp1:TR69 event found : 1 BOOT
17:59:45, 20 May.
ppp1:TR69 sending Inform message
17:59:45, 20 May.
17:59:45, 20 May.
17:59:44, 20 May.
17:59:43, 20 May.
ppp1:TR69 creating new session with ACS
17:26:37, 20 May.
ppp1:TR69 ConnectionRequest Failed
17:26:37, 20 May.
ppp1:TR69 ConnectionRequest: processing request from ACS
17:23:59, 20 May.
17:23:58, 20 May.
17:23:58, 20 May.
InformResponse:TR69 receiving message
17:23:58, 20 May.
17:23:58, 20 May.
17:23:57, 20 May.
17:23:56, 20 May.
17:23:56, 20 May.
17:23:55, 20 May.
17:23:55, 20 May.
16:22:16, 20 May.
16:22:16, 20 May.
16:22:16, 20 May.
16:22:16, 20 May.
16:03:09, 20 May.
16:03:09, 20 May.
14:15:20, 20 May.
14:15:20, 20 May.
12:59:01, 20 May.
12:59:01, 20 May.
12:03:54, 20 May.
12:03:54, 20 May.
12:01:15, 20 May.
12:01:15, 20 May.
11:37:29, 20 May.
11:37:29, 20 May.
11:06:37, 20 May.
11:06:37, 20 May.
11:02:22, 20 May.
11:02:22, 20 May.
11:02:19, 20 May.
11:02:19, 20 May.
10:33:54, 20 May.
10:33:54, 20 May.
09:28:58, 20 May.
09:28:58, 20 May.
09:12:02, 20 May.
09:12:02, 20 May.
08:35:01, 20 May.
08:35:01, 20 May.
08:29:01, 20 May.
08:29:01, 20 May.
08:20:01, 20 May.
08:20:01, 20 May.
07:50:59, 20 May.
07:50:59, 20 May.
2 REPLIES 2
Message 2 of 3
Re: 2nd Home Hub 6 rebooting...
Welcome to this user forum. @CyanideX
See this thread for plenty of suggestions.
https://community.bt.com/t5/Connected-Devices-Other/Best-router-for-Infinity-2/m-p/1737624#M138926
The cheapest is this one.
The TP-Link TD-W9970 N300 for about £35 or less. Very good value for money, and readily available locally,  easy to return if you are not happy with it.
There is a review here http://www.kitz.co.uk/routers/tplink_TD-W9970_review.htm
There is a quick setup wizard.
Login details
Broadband Username   bthomehub@btbroadband.com
Password bt
Even though you are not using a home hub.
edandjudy
Message 3 of 3
 I had two Hub 6 with same problem. I persuaded BT to send me another Hub 6. This 3rd one works perfectly. They must be some faulty Hubs around, or the sensitvity on some is to great.
