loochy750
Message 1 of 8
3rd party router that works with ipv6
Hi all
im looking for advice for a 3rd party router that supports ipv6 without much tinkering need to get away from the homehub i have a separate modem so not tied to built in modem models.
thanks in advance
7 REPLIES 7
Message 2 of 8
Re: 3rd party router that works with ipv6
Virtually all the TP Link and ASUS ranges support BTs implementation of IPv6. Not sure if there has been a change of policy, but Netgear originally said they wouldn't be implementing /56 PD so would avoid.
loochy750
Message 3 of 8
great thanks for the advice i will take a look at those
loochy750
Message 4 of 8
out of interests is there a list of fully working routers ?
loochy750
Message 5 of 8
would the below work?
Asus RT-AC87U
Message 6 of 8
The problem is many routers say they support IPv6 but they don't all support BT's implementation of /56 prefix Delegation. You would need to ask ASUS directly if /56 PD is supported on that particular model. As far as I'm aware their later models do but this model is quite old and may not.
Edit: This thread suggests that it does work. The problems the poster had were not because of the router.
davews
Message 7 of 8
Billion 8800NL R2 works fine on BT ipv6. Set up as per their website.
loochy750
Message 8 of 8
Hi thanks for the reply was looking at billion but the one below that better or worse
BiPAC 7800NXL
Triple-WAN Wireless-N 3G/4G LTE ADSL2+/Fibre Broadband Router
