Message 1 of 7
3rd party router
Hey looking for advice and information.
I'm getting connected to full fibre 900 next week and been looking for sh2 replacement. When I get connected I'll give a sh2 a go but from what I've read is not the best router.
I've noticed that the Asus routers got a lot of recommendations. What to look for choosing a router for full fibre broadband? Any recommendations?
6 REPLIES 6
Message 2 of 7
Re: 3rd party router
These are known to work well with the 910 / 110 package.
Asus RT-AX58U   £169
Asus RT-AX82U   £180
Asus RT-AX88U   £299  (Expensive but my choice)
There are more choices but these "WILL" work with the premium package.
Buy once.. Buy right.😉
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 7
Thank you. So it has to be one of the RT-AX models?
Message 4 of 7
You don't need the DSL models as you already have a modem.
Message 5 of 7
The RT-AX models are all cable routers and WiFi 6 compatible.
if you are going down the third party router direction (which I think is correct) you are future proofing yourself.
Message 6 of 7
Thank U for all ur help. Is router Asus RT-AX86U going to work? Its a bit cheaper than AX88
Message 7 of 7
