Message 1 of 3
5.5mm x 3.0mm Female to 5.5mm x 2.1mm Male
Hey everyone
I want to connect a UPS to my BT Smart Hub 2 and I was hoping to input the BT standard plug into the UPS then a the correct cable and connector into the back of the Smart hub.
Issue is I need 5.5mm x 3.0mm Female to 5.5mm x 2.1mm Male DC adaptor to do it.....All the kits I looking at are the other way around and I am unable to locate a 3.0mm Female at all.
Anyone know of one?
Thanks everyone
2 REPLIES 2
Message 2 of 3
Re: 5.5mm x 3.0mm Female to 5.5mm x 2.1mm Male
Farnell do the plugs, but I never found a socket when I looked a few years back.  Might be easier to make up your own lead.
If memory serves, the old Home Hub 5 type A used the same plug, so you could cannibalise an old one off there.  (The type B was different)
Message 3 of 3
[Third party link removed]
I think this is what you're looking for.
[Mod edit - third party link removed, but this showed availability of this product on Ebay]
