Newbie
Message 1 of 1
ASUS DSL-AC68U configuration when using BT Superfast Fibre 3 Plus ?
When I got BT Superfast Fibre 3 Plus installed I also got a new Asus DSL-AC68U router.  When I am connected directly to the router using CAT5/6 cable I get extremely good speeds.  When I use Wifi this is massively reduced with intermittent dropped connections.  I am running their most recent asus firmware version 3.0.0.4.384.  I have seen people suggest this is linked to 802.1Q not being enabled on the router.  When I try and enable 802.1Q it does not connect at all to the internet.  What are the correct values for VLAN ID and 802.1P ?  I have tried 101 in the VLAN ID and left 0 in the 802.1P field but this makes no difference.
Thanks in advance for any input.
