Reign_in_Beard
Message 1 of 4
ASUS DSL-AC88U IPV6 problem.
Hello.
I have just picked up a new ASUS AC88U Router. I have infinity running fine on it but cant seem to get IPV6 working.
I have set connection type as native, DHCP-PD is enabled, autoconfiguration is set to stateless, connect to dns server auomatically is enabled and enable router advertisment is enabled. The prefix length I am unable to enter but it should be 56? But it doesnt work at all. When I run the test on Test your IPv6 I get 0/10 so I've clearly gone very wrong somewhere.
Has anyone got any ideas to help? Have I missed something somewhere?
3 REPLIES 3
Reign_in_Beard
Message 2 of 4
Re: ASUS DSL-AC88U IPV6 problem.
In the IPv6 system log all fields are full except the Wan IPv6 address and the DNS, so that would seem to be the issue. Any ideas?
Pinklady-1986
Message 3 of 4
Hi did you get this resolved at all? I have just brought the same router and am having the same trouble.
gibbylinks
Message 4 of 4
Hi,
Are you running the latest firmware?  My IPV6 is working fine, but my config page is subtley different to yours
