JimmyPoP_79
Message 1 of 9
ASUS DSL-AC88u won’t verify ISP number
Hi,
I’m totally new to this so I shall try and explain as simply as possible. I’ve recently been given a new router. The asus dsl-88u. I’ve removed my old home hub and plugged the dsl cable that was previously in my home hub into the asus. All the lights come on apart from the internet light.  I go to 192.168.1.1 and start the setup process for the router. It detects what model the router is and then asks me which country I live in and what my ISP is. I put UK and BT infinity. It then asks what my username and password is for my ISP. I put:
username: btbroadband@btbroadband.com
password: BT
It then searches to check my credentials but after 5 mins it times out and asks to check again. It continuously times out I matter how many times I check. If I choose to cancel the search a screen pops up and tells me that my password and username were authenticated but my ISP won’t give the router a valid isp number. Am I missing something here?
thanks in advance.
8 REPLIES 8
imjolly
Message 2 of 9
Re: ASUS DSL-AC88u won’t verify ISP number
User is bthomehub@btbroadband.com and password anything you want. BT if you want
JimmyPoP_79
Message 3 of 9
Hi,
Thank you for the speedy reply. I’ve just tried using the username you gave me and it still won’t work. Just to clarify, I’ve got a double master socket that BT installed when I took out infinity several years ago. I’m just running an RJ11 cable from the socket to the dsl port on the back of the router. I was under the impression this router would be plug and play. I never had any issues with the Netgear router I used previously.  Also as a note, I checked to see if the router needed the firmware upgrading but it was already running the latest update.
Regards
RobertM
Message 4 of 9
This may sound a daft question but has the router got a built in modem? If not is there one between the bt socket and the router?
I mention this because you say the broadband light is not on which to me indicates no broadband connection hence the timing out.
TimCurtis
Guru
Message 5 of 9
@JimmyPoP_79
Was this a new new router or one that had been previously used?
What HomeHub were you replacing?
I'd try a full reset by pressing a pin into the reset socket for I guess about 10secs and then try again.
As an aside for the username you can use anything @btbroadband.com so changing the username you started with wouldn't have made any difference.
@RobertM
Yes it has a built-in modem
JimmyPoP_79
Message 6 of 9
Hey,
Thanks for the reply. The router was new. It’s replacing a Netgear D6400 which replaced the BT Smart Hub last year.  As for doing the full reset, I’m assuming I need to do that while it’s  plugged in and switched on?
Regards
JimmyPoP_79
Message 7 of 9
Hi,
It has a modem built in.
RobertM
Message 8 of 9
Thanks for that I did wonder.
TimCurtis
Guru
Message 9 of 9
@JimmyPoP_79
Yes , have it switched on for doing a reset.
