Mustafa_Islam
Message 1 of 4
Access point connected to power line sometimes loses Wi-fi
I have another access point connected to a power line adapter in another room, the WiFi works most of the time. But occasionally the WiFi just drops, it shows the WiFi is connected but nothing loads. It’s takes a minute to actually reconnect. I have tried another router. The wired connection to my pc doesn’t disconnect however.
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
3 REPLIES 3
Mustafa_Islam
Message 2 of 4
Re: Access point connected to power line sometimes loses Wi-fi
Never mind, did some digging in the wireless settings of the router
Devon_Dave
Distinguished Guru
Message 3 of 4
Just wondered what settings you changed, it may help others with a similar issues.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Mustafa_Islam
Message 4 of 4
There was a settings called TX bursting which is apparently used for G devices, so I disabled that since I don’t have any G devices and the problem seems to have disappeared. I also reset and resynced my power lines.
