brent99
Newbie
Message 1 of 2
Access points
Help please, just had a new BT smart hub type A installed last week. Which we have an RJ45 plug and cable plugged in the back to a Netgear access point N150 at the other end of the house. This is our lounge too far for wifi. We then have a cat 5 cable plugged into the Netgear 150 which goes to an access point Netgear WG602 which is in our kitchen, 3 thick walls away. The nether devices since we have had the new hub seem to keep dropping out. Can someone recommend replacement devices for the nether which will allow us to plug in and carry on working please. Many thanks
1 REPLY 1
lnajr02
Message 2 of 2
Re: Access points
I have just installed a BT Whole Home Wi-Fi system, the discs can be connected using CAT 5 if your home has problems with Wi-Fi, check out the BT Shop, two discs set are current on offer.
