narabdela
Message 1 of 13
Accessing wrong homehub.
Trying to access my Homehub5 with the usual 192.168.1.254 login (which I've used before several times), but I'm now getting my next door neighbour's Homehub6 instead.
Any ideas what on earth is happening here?
Tags (1)
12 REPLIES 12
imjolly
Message 2 of 13
Re: Accessing wrong homehub.
you need to be connected to your home network to access the hub
gg30340
Message 3 of 13
Do you have powerline adaptors? It could be that they also have powerline adaptors and your signals are crossing.
Keith_Beddoe
Message 4 of 13
You must be connected to their wireless network instead, have you ever connected to it in the past, and saved the details?
If so, then delete their wireless settings from your computer.
narabdela
Message 5 of 13
Obviously.
narabdela
Message 6 of 13
Yes. That's a possibility. Though I'm connecting to the hub wirelessly from this laptop.
narabdela
Message 7 of 13
No, I'm not. They have a secure network, as have I, and no, I've never been connected to their network.
Keith_Beddoe
Message 8 of 13
Then login to the home hub and select the restart option, see if your home hub restarts. You would have needed their admin password to restart theirs.
gg30340
Message 9 of 13
Can you check your wireless connection on your laptop to see the name of the wireless network it says you are connected to.
narabdela
Message 10 of 13
That was the first thing I did. However, your previous suggestion re. powerline adapters seems to have been correct. I've unplugged the two that I use for my BT Tv box and the problem has resolved.
I now have to sort out the powerline adapter problem or rethink my BT TV/Sport subscription. Aaaaargh!
