aangus
Message 1 of 14
Adding a device to Network Home Hub 3
Hi
I 'm having problems getting my bluray player connected to the network.
I've gone to Port Forwarding to add an application but have no idea what numbers to input?
Does anyone know or can help.  Much appeciated.
angus
13 REPLIES 13
Message 2 of 14
Re: Adding a device to Network Home Hub 3
you bluray should find its connection automatically port forwarding should not be needed
aangus
Message 3 of 14
Hi john46
My bluray found the internet with my last router but since I have changed to the Home Hub 3 it cannot find a connection to the internet.
I'm stuck for reasons.
Thanks for your reply
angus
Message 4 of 14
What was the last router you were using?
aangus
Message 5 of 14
Hello Keith
It was a virgin broadband Netgear WGR614 v9 54 Mbps 4-Port 10/100 Wireless G.
angus
Message 6 of 14
@aangus wrote:
Hello Keith
angus
Are you trying to connect the BluRay device using wireless or Ethernet?
The Netgear would have been on a different IP subnet than the home hub, so you may have to reset the network settings on the player so that it gets an IP address from the new subnet.
aangus
Message 7 of 14
its connected by ethernet, i've just done another auto set up on the player. It detects a network but cannot find an internet connection.
thanks
aangus
Message 8 of 14
Hello Keith
I'm trying to do a software upgrade. the LAN is detected but it is not finding the internet to upgrade.
Message 9 of 14
I assume that your PC that you are using is connected to the home hub?
If it is, then it could simply be a DHCP issue between the player and the home hub.
You may find that if you manually setup the player to static IP settings, it will help.
There was a similar issue here with a different device
Connecting Humax FoxSat HD (Free Sat receiver) to your Home Hub.
There is a guide to setting up static IP addresses here
Using static IP addresses on your home network
aangus
Message 10 of 14
do i need to go to port forwarding ?
I only have a blu ray and my computer wired to the hub.
thanks
