Message 1 of 6
Adding another BT hub to act as a repeater
I followed a thread for the above topic to set up a repeater.  That worked fine, but the 2nd smart hub that’s acting as a repeater is constantly flashing purple, I assume as it’s not connected to broadband?  I tried updating the settings to turn of the status light, but it’s still flashing.  Any ideas on how to stop it?
thanks
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: Adding another BT hub to act as a repeater
You're correct in your assumption. The only option is to cover it, eg with tape.
Message 3 of 6
Haha, I guess that might be the answer.  Thank you.
Currently each hub is transmitting a different wi-fi name and different password.  Can I change them to be the same and is there any benefit in doing that?
Anonymous
Not applicable
Message 4 of 6
Not really. There is a school of thought that suggests separate SSIDs is preferable, as you can be certain that you're connected to the nearest one.
Message 5 of 6
Ok thanks for the info 👍
Message 6 of 6
Just make sure they are on different channels or they will interfere with each other.
