Message 11 of 18
Re: Advice needed re 3rd party router/modem please
Rather than a separate router and extenders/hotspots, you may wish to consider a combined mesh system. There are numerous to choose from such as Netgear Orbi, TP Link Deco M5, Linksys Velop or Ubiquiti Amplifi
Message 12 of 18
If I stayed with the BT HH2, would any of the above be compatible with it? in particular the TP Link Deco M5? Also would you recommend in-line over wireless extenders and hotspots? Thank you very much.
Message 13 of 18
All the devices mentioned remove the need for the SH2, they are complete systems with router and wifi access points. Wired connections will always be the most stable and fastest connection, but it is a trade off between that and convenience of wifi.
Message 14 of 18
Thanks what is SH2? I'm considering the MESH system you use but a wired connection from this to my Xbox and the rest using the system.
Message 15 of 18
The SH2 is the BT hub. I don't use a mesh system, it was just a suggestion to consider.
Message 16 of 18
I use the TP Link Deco M5 - a mesh of 3 has transformed performance round the fairly large old house.  I resurrected the old ECI modem and put away my collection of HHs (3, 4 and 5).
Message 17 of 18
Great I’ve just ordered it, I’m hoping it’s easy to setup, thanks for everyone’s help and support and everyone have an amazing Xmas and new year 🙂
Message 18 of 18
Connection type is PPPoE and the username and password are the generic bthomehub@btbroadband.com and BT respectively.
