techytechno
Message 1 of 2
After having some new windows put in my wifi signal has gone to **bleep**..
This week we had some new windows put in, one of the rooms where new windows were being put in was the room with the hub. Due to everything needing to be covered over my mum moved the hub along with some other plugged in electronics into the far corner of the room. But due to the room's small size it was not very far and covered it all over with several sheets. After removing the sheets and moving the hub away a bit from the other electronics back to where it was the wifi has been useless.
Any one know what might have happened to cause the almost non existance of wifi signal?
Many Thanks.
1 REPLY 1
Message 2 of 2
Re: After having some new windows put in my wifi signal has gone to **bleep**..
Make sure all the cables are plugged in correctly then carry out a factory reset of the modem by pressing a pin into the recess button on the rear for about 20 seconds. This often sorts out wireless problems.
