rpeterjones
Message 1 of 4
Alexa app voice only works with firewall disabled
Is there a way of allowing the voice option in the Alexa app to work on the network without disabling the firewall, which I have had to do?
3 REPLIES 3
Message 2 of 4
Re: Alexa app voice only works with firewall disabled
Welcome to this user forum.
You should not need to do that, as the firewall is only Internet facing and should not affect your local network.
Which BT Home hub are you using?
rpeterjones
Message 3 of 4
It’s a home hub 4.
Message 4 of 4
