d264p8
Newbie
Message 1 of 3
All URL History
We are worried about what our son is wathcing online. He uses incognito and private browsing.
Is there a way to access the url history through the BT hub?
2 REPLIES 2
Message 2 of 3
Re: All URL History
Welcome to this user forum. @d264p8
No, that is not possible on any of the BT Home Hubs.
You may find this helpful http://bt.custhelp.com/app/answers/detail/a_id/46768/~/how-to-keep-your-family-safe-online-with-bt-p...
Moderator
Moderator
Message 3 of 3
Re: All URL History
@d264p8 Welcome to the community and thanks for posting your question, I can confirm that what @Keith_Beddoe has advised is correct the web browsing history is not stored on the Hub.
I'd really recommend that you set up Parental Controls on your broadband and this will help you control what can be accessed over your internet connection. You can customise the filters to what suits your family's needs and is controlled by primary BT account holder on MyBT.
