james1232
Message 1 of 4
Amazon echo
I have a home hub and was wondering whether the issue has been fixed where you couldn’t use bt network for amazon echo. I’m guessing this has been fixed but just want to make sure.
3 REPLIES 3
Message 2 of 4
Re: Amazon echo
don't know what problem you refer to but I use echo and never had any problems on my BT broadband and hub
james1232
Message 3 of 4
Re: Amazon echo
Thanks for your reply. It was just that I could see some issues on the web where in setup when you enter wifi password it says can’t connect to this network. However these web results are dated quite a bit so was wondering whether the issue had been fixed. I’ll probably just take the risk and get one
Message 4 of 4
Re: Amazon echo
@james1232
more likely people not turning off  the hub smart setup
