eliotrw
Message 1 of 4
Anyone Using a RT-ASUS AC8X router (emphasis on the RT part) with Ultrafast 2 (FTTP not C)
I believe as I have a FTTP setup through BT and therefore have a fibre box on the wall, I can just get a RT-ACxx model as opposed to DSL-ACxx but just looking for comfirmation this is the case
3 REPLIES 3
Message 2 of 4
Re: Anyone Using a RT-ASUS AC8X router (emphasis on the RT part) with Ultrafast 2 (FTTP not C)
Yep, the ONT is a modem so you don't need a modem/router just the router (RT) model.
eliotrw
Message 3 of 4
Any ideas what will need to be done config wise on the Asus? or will it just jump to life when plugged into the Modem?
Message 4 of 4
I haven't got an ASUS so can't tell you the default config, but you will definitely need to enter PPP username of bthomehub@btbroadband.com as username and bt as password when prompted.
