tech3475
Message 1 of 3
Anyone know how to get a DD-WRT VPN server to work behind a HH5?
Recently I picked up a router running DD-WRT with the intention of using it as a small VPN server for when I'm away from home, unfortunately I'm forced to use it behind a HH5 which I need because of my Youview box.
I've tried using port forwarding via the default PPTP option and DMZ but it doesn't work except when I used my old white Infinity modem and connected the DD-WRT router directly it worked instantly so I know the HH5 is part of the problem.
Anyone here have any possible solutions? BT just referred me to a premium support line.
Thank you.
2 REPLIES 2
wedd1ng528
Message 2 of 3
Re: Anyone know how to get a DD-WRT VPN server to work behind a HH5?
You might be better off asking the question on the DD-WRT forum. www.dd-wrt.com will take you to the home page and then all you need to do is click on the "Forum" box.
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
Jonkarra
Expert
Message 3 of 3
Are you using neat traversal? The hh5 will not be able to forward on esp or ah.
