geecee20
Message 21 of 42
Re: Apple iCloud access on BT Home Hub
Thanks it worked for me too.  😁
greedyfreddy
Message 22 of 42
Would love to try this but parental controls etc has disappeared from my account page 😞
Moderator
Moderator
Message 23 of 42
Hi @greedyfreddy  sorry that you do not have the Parental Controls option available on your BTID. Do you have any open orders on your account at the moment?
Post back and let me know.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
TJD11
Newbie
Message 24 of 42
Yep, had the same problem this week.
Just had to allow iCloud on my parental controls plus allow file sharing which was previously disallowed.
Come on BT basic stuff here which must be affecting a lot of customers.
Also make accessing Parental controls a lot simpler please. I use the app on my phone & it’s like trying to find a needle in a haystack.
greedyfreddy
Message 25 of 42
yes, have a new order - smart hub came today
greedyfreddy
Message 26 of 42
And installed new Smart hub 2, the problem still persists
Moderator
Moderator
Message 27 of 42
Hi @greedyfreddy  thanks for getting back to me and sorry the problem is persisting. You should be able to access the Parental Controls once the order is closed off. I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to check they are enabled on your BTID for you.
Check here: https://community.bt.com/t5/notes/privatenotespage
cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 28 of 42
Hi @James72  @TJD11  & @gugglebum
Thanks for your posts.
Sorry you've had problems accessing iCloud from your BT connection.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
Cushstavo
Newbie
Message 29 of 42
Hi,
My IOS devices aren’t backing up over wifi to icloud. I have tried accessing icloud and i think it is being blocked by the BT DNS servers. When i use google’s DNS servers from my imac i can access icloud, however despite adding www.icloud.com as an allowed website on BT parental controls i still can’t access it from my mobile devices. I have also noticed that this affecting me streaming my sky go on  xbox and iphone. It all works okay when parental controls are disabled, but with children in the house i don’t want to do this for any length of time. Any help will be greatly appreciated.
Domski
Message 30 of 42
I have exactly the same problem since early August I would say. I can’t access any of my Apple iCloud features (photos, findmyiphone) without disabling parental controls completely (which I don’t want to do with 3 teens in the house) or otherwise coming off Wi-fi and using 4G. I have tried adding iCloud.com to my list of allowed websites but this hasn’t worked.    Please help BT!
