AJ1983
Message 1 of 2
Are Discs better than a BT Wi-Fi Extender 1200?
Hi, I’ve recently upgraded and have 2 BT WiFi discs. They’re replacing a BT Wi-Fi Extender 1200 plug in. Will the discs do a better job? And could I use the 1200 in combination?
Cheers!
Tags (5)
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: Are Discs better than a BT Wi-Fi Extender 1200?
Hi, @AJ1983 welcome to the community and thanks for posting, the discs should work better as they form a wifi mesh network which should provide better coverage and allow your devices to switch between discs without losing connection. The Wi-Fi Extender 1200 can still be used but it won't be part of the mesh network.
Neil
