yabadaba
Message 1 of 4
Asus DSL-AC68U IPv6
Currently IPv6 is set to Disable, but if I want to enable it can anyone advise what settings I need to enter please?
From what I can make out I think the 'Connection Type' should be 'Native', but then it asks for 'Interface' (PPP or Ethernet), 'DHCP-PD' (Enable or Disable), 'Auto Configuration Setting' (Stateless or Stateful), 'Connect to DNS Server automatically' (Enable or Disable) and 'Enable Router Advertisement' (Enable or Disable). I could probably guess these, but would prefer someone to say what they should be at!
Thank you.
3 REPLIES 3
Liam_
Expert
Message 2 of 4
Re: Asus DSL-AC68U IPv6
You could try the settings below.  It's the closest match to the configuration I have on my router.  Some of the options don't appear on the FritzBox but are handled in the background, apparently.
Native
PPPoE
DHCP_PD Enable
Auto Configuration Setting Try Stateful
Connect to DNS Server automatically Enable
Enable Router Advertisement Enable
yabadaba
Message 3 of 4
Thanks, will give that a go
TimCurtis
Recognised Expert
Message 4 of 4
Actually
PPP
Stateless on my AC68U otherwise agree.
