GeekGamming
Message 1 of 22
Asus RT-AC5300
Hello i am struggling setting up my device to use instead of my current router issue is i can connect it to the original router and it works fine but i want to have it as a stand alone router i have tried to follow guides but with no luck anyone got any ideas of why it isnt working and how i can fix this issue 🙂
Tags (1)
21 REPLIES 21
licquorice
Message 2 of 22
Re: Asus RT-AC5300
That device is just a router, not a modem/ router. You can't use it stand alone with fttc, you need a modem as well.
GeekGamming
Message 3 of 22
Re: Asus RT-AC5300
So would i need to make it connect to my current BT modem? If that is the case any recomendation?
licquorice
Message 4 of 22
Re: Asus RT-AC5300
I'm not entirely sure from your posts what broadband service you have, you seem to imply you currently have a BT modem and a separate BT hub. Can you clarify what service you currently have.
If you have FTTP with an optical modem (ONT) you can connect the Asus directly to the ONT without using the BT Hub.
If you have superfast FTTC, you need a standalone modem (such as Openreach Huawei HG612) and connect the Asus to that.
If you have ultrafast FTTC (G.Fast) then you are going to be struggling to source a modem to use with the Asus.
The BT hub doesn't have a modem only mode, so if you use the Asus in conjunction with that you will just be using the Asus as an expensive wireless access point.
GeekGamming
Message 5 of 22
Re: Asus RT-AC5300
Hi there yeah i belive i am currently on the superfast deal or the one that is £39.99 with estimated speed of 100 if that helps?
licquorice
Message 6 of 22
Re: Asus RT-AC5300
Not really, that's just marketing  guff not the technology that delivers it.
How is your broadband delivered, by copper or a fibre directly to your home? Do you have an optical modem (ONT) like this?
GeekGamming
Message 7 of 22
Re: Asus RT-AC5300
My broadband is done via fibre i belive i will take a pic of it when i get home
GeekGamming
Message 8 of 22
Re: Asus RT-AC5300
hey i tried to upload the pics but due to the picture quality it wont let me on the forms if u got a email i can send them to that would be great but i got the new smart hub 2 i belive with my deal and as stated before got 100mbps
licquorice
Message 9 of 22
Re: Asus RT-AC5300
Reduce the size of the pictures to post.
licquorice
Message 10 of 22
Re: Asus RT-AC5300
Do you have an ONT like the picture I posted?
