Message 11 of 15
Re: Authentication issues with smart hub
Buy a decent third party VDSL Modem/router. They start in price for a single band one at £30 up £200+ for an all singing dancing one.
GrandadClive
Message 12 of 15
Hi gg thanks for your reply, to add to the problem I have a bt 3g mobile phone smart box attached to the modem will that also work with new modem/ router?
Message 13 of 15
I don't have any knowledge of a bt smartbox so I can not say for sure but I would imagine it will not be dependent on having to work with a BT Smarthub and should work with any VDSL Modem/router.
GrandadClive
Message 14 of 15
Yes thank you, I thought the same. I will try your suggestion and post again in the future.
Clive
GrandadClive
Message 15 of 15
Hi gg
Solved the Authentication Problem, but not to my satisfaction, swopped in my old home hub 3 and modem and everything works EXCEPT the 3g smartbox aaaarrrgggghhhh. Oh well bt fault line here go!
