Davemarsden132
Message 1 of 4
BT 0 help
So BT in all have been rubbish, no help on twitter, no help on email and no help over the phone. My wired connection is good, 250mbps.... My wireless and homeplugs connection is **bleep** 2mbps.
Ive had about enough of not being able to see my CCTV because of BT crappy router and connection etc.
So my question is,
I have fibre to the property, and want to buy one of these
TP-LINK Archer C5400X WiFi Cable & Fibre Router - AC 5400, Tri-band
Do i just connect this to my Huwawi box  thingy and remove the BT router in its place?
Cheers
Dave
3 REPLIES 3
licquorice
Message 2 of 4
Re: BT 0 help
Yes.
Enter username of homehub@btbroadband.com and password BT when prompted
Davemarsden132
Message 3 of 4
Re: BT 0 help
Do i enter them in the new router settings or will it show it up when i try to connect to it?
Cheers
licquorice
Message 4 of 4
Re: BT 0 help
It will be part of the setup process for the new router if it has a setup wizard (most TP link devices do)
PS Please delete the link in your OP, it is against forum rules.
