Kalel2507
Newbie
Message 1 of 2
BT 11ac 1200 nat type strict Xbox one
Recently bought the bt 11ac works well enough but plug my Xbox in or connect wirelessly and has made my nat type strict tried port forwarding and dmz nothing has worked
1 REPLY 1
anthonyUK
Expert
Message 2 of 2
Re: BT 11ac 1200 nat type strict Xbox one
It appears you need UPNP enabled.
I had all the required ports forwarded on my router but UPNP still opened a port (which was already open) for Teredo which is an IPv6 to IPv4 tunnel that it uses.
