nandrews
Message 1 of 2
BT 610 wifi extender no longer visible
I installed a BT 610 wifi extender and connected my PC's to it, but I was advsied to change the SSID on the 5Ghz side to match that for the 5GHZ on the router.
Having tried to do that the extender is no longer visible on my network!
Is there a way I can reset it back to factory, so I can start again?
Nigel
1 REPLY 1
Message 2 of 2
Re: BT 610 wifi extender no longer visible
