helenmac1cat
Message 1 of 2
BT Blocking VOIP Servers? (Mumble)
I'm hosting a mumble on my Raspberry Pi Micro Computer and after setting it up and testing it out, after I quit mumble next time I try to reconnect it says "Server connection failed: Connection refused." which translates to 'something is blocking this'.
It's not a firewall on my local machine(s) as i've tried it with and without it being enabled and it's not the ports not being opened, I have opened all the ports for both TCP and UDP.
This brings me to the conclusion that the problem lies with BT Blocking the port 64738 (Mumble port) or voip servers all together.
Can anyone else shed light on this issue?
1 REPLY 1
Message 2 of 2
Re: BT Blocking VOIP Servers? (Mumble)
BT Parental controls can cause issues.
If you do not need them, then you need to uninstall them.
