IanRC
Message 1 of 3
BT Broadband Extenders with BT Ethernet switch
Hi, at the moment I have a pair of broadband extenders, one connected to my Smart Homehub router and the second connected to my you view box. Would it work OK if I plugged a 5 port ethernet switch into the second extender, then run cables from that to my youview box and other devices? Any help appreciated
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: BT Broadband Extenders with BT Ethernet switch
yes. that would be the same as my setup and works ok. what speeds does the switch support?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
IanRC
Message 3 of 3
The one I am looking at is the BT Gigabit switch. Thanks for your reply, I can go ahead and order it now.
