cvld
Message 1 of 12
BT Broadband High ping/latency spikes
I'm having high ping spikes since I've got it (almost 1 year ago). Let me know what info you need from me to have a check pls.
11 REPLIES 11
DavidM
Moderator
Moderator
Message 2 of 12
Re: BT Broadband High ping/latency spikes
Hi cvld and welcome.
Can you give us as much detail as possible. Please post your hub stats, speed test results and tracerts and we'll try to help.
Cheers
David
mrmarky
Message 3 of 12
@cvld disable IPv6 if your on a windows 10 machine, this is what's causing the problem.
i was in same boat, randomly every few hrs for about 5 minutes my ping would go insane but dropping back to IPv4 fix's the problem.
if it's xbox or playstation though you will be in for a wait, as we can't manually turn off IPv6 on the router
cvld
Message 4 of 12
Hi,
Here are some details:
BROADBAND UNLIMITED Your download speed range 14Mb - 17Mb Upload speed 1Mb Your Stay Fast Guarantee 3Mb
Postcode: PL31 2HR
https://www.speedtest.net/result/9168212908
For tracerts give me the hostname you would like to see.
JohnC2
Moderator
Moderator
Message 5 of 12
Hi @cvld thanks for posting back. Please can you run the tracerts to the BBC website. Also please check out Broadband help on how to get your hub stats and run a speedtest. Once you have completed these please post the results.
cheers
John
cvld
Message 6 of 12
I'm back with all the details. Speedtest has failed twice, unfortunately.
23:42:27, 22 Mar.( 106.540000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
23:42:26, 22 Mar.( 105.270000) DSL line rate: 1191 Kbps upstream, 21336 Kbps downstream
Keith_Beddoe
Message 7 of 12
Try the BT Wholesale Speed Test instead https://speedtest.btwholesale.com/
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
cvld
Message 8 of 12
I don't have a phone, I only have the internet.
cvld
Message 9 of 12
Up?! The latency is incredibly high.
Tags (1)
PaddyB
Moderator
Moderator
Message 10 of 12
Hi @cvld,
How are you connecting to the internet? If it's wirelessly please can you try a wired connection to see if that makes a difference?
PaddyB
