Message 1 of 14
BT Broadband wiring and connections
Good afternoon. I have a problem with wiring. So I got a new house and it has a installed openreach modem near my entrance door. BT modem and TV modem needs to be on the other end of the house in sitting room. Also, I have a phone line from the same Openreach box near entrance to the sitting room near TV. The problem is : I do not want wires as long as from Openreach modem to BT modem through all the hall and sitting room, because it means, that I would need to take off all of the skirts and put the wire under them. Are there any options of connecting a Openreach modem to phone line socket, which goes out near the BT modem and TV moden in sitting room?  Thanks for any ideas!
13 REPLIES 13
Message 2 of 14
Re: BT Broadband wiring and connections
@KarleonP
Welcome to this user forum.
I assume you have something similar to this installed?
If that correct?
Message 3 of 14
You appear to be using the term 'Modem' for everything. If you clarify what each box is exactly it will help enormously.
Message 4 of 14
So.. I have Openreach stuff installed with a phone line socket in wall, which goes out in the sitting room near TV/BT modem.
Message 5 of 14
That I would know exactly how it's called 😄 I sorted how to add pictures, as they are all over sized as my belly . I'll put some pictures 🙂
Message 6 of 14
That is one of the new optical modems,
Where is that cable from the middle yellow socket going to at the moment?
It looks a mess, is that how the builders left it?
Message 7 of 14
Through all of the flooring to the sitting room. 20 meters of cable 🙂
Message 8 of 14
What did you mean when you said TV modem, I assume you are a BT Broadband customer with a BT Home hub on the end of the cable?
Message 9 of 14
Yes. BT customer with BT Hub modem on the other end. And from the BT Hub cable goes to BT TV Box
Message 10 of 14
I understand now. This is a very common problem.
What speed is your Internet connection supposed to be?
PS, you do not need the filter on the phone socket.
