Message 1 of 5
BT Broadband
Just installed BT hub for elderly relative  (property in 'black spot' therefore TV aerial no good).
She cannot really afford another £20 or so for TV package so purchased Firestick.
Also has TV in bedroom and wants that 'connected'. Therefore I think I will need to purchase
another Firestick, but what else do I need to do/purchase.
Does the bedroom TV need another connection other than 'power'.  Eg  extender  or am I good to go
with just power and firestick.  Thanks
4 REPLIES 4
Message 2 of 5
Re: BT Broadband
the firesticks should connect back to the BT router using WIFI  you will just need setup wifi on firestick
Anonymous
Not applicable
Message 3 of 5
Re: BT Broadband
Best bet would be to move the existing Firestick to the bedroom TV temporarily  to test WiFi  signal before  buying another.
Message 4 of 5
Re: BT Broadband
Sorry to be a bit dense about this but are you saying that apart from the Firestick, the only connection to the bedroom tv will be the power connection.  So after setting up Firestick to wifi then i am good to go ?
Message 5 of 5
Re: BT Broadband
