richardshu
Newbie
Message 1 of 5
BT Business Hub 3 DHCP query
I need to configure a BT Business Hub 3 with a static address and DHCP range which is different from the defaults available. This is fine, however I am unable to see an option to set the gateway and dns addresses used by the DHCP clients. Is anyone able to point me in the right direction ?
4 REPLIES 4
Message 2 of 5
Re: BT Business Hub 3 DHCP query
Are you a BT Business user?
richardshu
Newbie
Message 3 of 5
Yes, well not personally. I work for a university and we have six lines which I am configuring. They work fine but I need customise the internal IP addresses they use. We used to use the old BT voyager modems for this and it wasn't a problem. However these Business Hubs don't seem to have many options regarding the DHCP server.
Message 4 of 5
As the university lines are business lines, please can you post on the BT Business forum, as this is the residential forum, and only deals with the domestic home hubs. The business hubs have a different configuration.
 http://business.forums.bt.com/
richardshu
Newbie
Message 5 of 5
Thanks, didn't realise there were two places.
