coliander
Newbie
Message 1 of 5
BT Business Hub BT2700HGV and Asus RP-AC68U issue
Hi there, I've recently purchased an Asus RP-AC68U repeater to extend the range of the wireless signal provided by my BT Business Hub.
During setup, the repeater successfully finds my router's SSID and I enter my Wireless key as normal.
However once set up us complete, I find that there is no connection to the router whatsoever. The wireless status lights on my repeater flash when I complete setup as if they are trying to connect to the router but no connection is made.
I have successfully tested the repeater with a friend's router, following precisely the same steps and managed to make a successful connection, which leads me to assume that the problem lies with my Business Hub.
Anybody able to shed some light on the matter?
Thanks.
4 REPLIES 4
Message 2 of 5
Re: BT Business Hub BT2700HGV and Asus RP-AC68U issue
Are you a BT Business customer?
coliander
Newbie
Message 3 of 5
Personally, no. However the couple who I reside with are.
Message 4 of 5
So the connection you are using, is a BT Business broadband connection?
This is the BT Residential forum.
There is a separate forum for that service, as router configurations are different owing to static Internet IP adresses.
 http://business.forums.bt.com/
coliander
Newbie
Message 5 of 5
Thanks 🙂
