Cliff
Message 1 of 3
BT COOKIE SETTINGS
Every time I go to my bt email or MYBT, I get the box about cookie settings,it seems like I've been setting the cookies forever & i'm now getting fed up with it.Do I have to keep setting my preference every time or once I've set them are the settings retained ( remembered ).
2 REPLIES 2
Message 2 of 3
Re: BT COOKIE SETTINGS
It may be that your browser has been set to delete cookies when it closes. You will need to go into the browsers settings and check.
Cliff
Message 3 of 3
My browsers,Edge & Firefox are set to delete cookies when they close.I reset both to do not delete,restarted the computer & the pop up box is still there,i closed both browsers,the box is still there.It's annoying but I can live with it I guess.
