andymerrett2
Message 1 of 2
BT Cloud for Mac: removing software
I decided to do a quick trawl of BT Cloud for Mac, so downloaded the software, but have subsequently decided that I don't want to use it on my machine.
However, it's not listed in the login items, yet it starts up automatically every time I start up the Mac, and there seems to be no obvious way of uninstalling it. Can you let me know how to do it?
By way of some comparison, Dropbox behaves itself by being listed in the login items for the appropriate user. Why does BT Cloud not do this?
1 REPLY 1
Message 2 of 2
Re: BT Cloud for Mac: removing software
