Message 1 of 2
BT Compact Disc Problem
Hi,
One of my BT discs is continually flashing the blue light.   I've powered down/powered up and reconnected to my BT hub and moved the BT disc, but it is still flashing the blue light.  When I reconnected to my BT hub it also started to flash a white light.
Any ideas what is wrong.  Is the BT disc broken?
1 REPLY 1
Message 2 of 2
Re: BT Compact Disc Problem
Assuming you mean Complete Wi-Fi Disc:
All explained in the user manual but if you don't have on you can find it here.
BT-Complete-Wi-Fi-Disc-User-Guide.pdf
