Message 11 of 14
Re: BT/EE Hybrid flashing red bars (again)
Message 12 of 14
I have this problem as well. Put the EE device in the front window connected by ethernet cable to the BT Smart Hub. Flashing red bars. Haven't bothered to contact BT as they obviously don't know what's causing it, according to previous posts. I've disconnected the device until BT and EE find a fix. If my broadband goes down I'll use a hotspot provided by my mobile operator until it comes back. On the bright side, the extender is working well and that was the main reason I upgraded to the Smart Hub.
Message 13 of 14
Just moved over from BT to EE and getting the flashing red bars on the hybrid connect. Anyone know of a fix?
Message 14 of 14
hi, same issue, just moved over from BT to EE and getting flashing red bars on EE hybrid connect. previously had the hybrid connect with BT placed in the same location and worked fine.
