madwedge
Message 1 of 2
BT Extender 1200 settings confusion
Hi. I originally had a BT Extender 600 and this seemed to literally extend my network using the same DHCP settings as my main D-Link DIR-868L Wireless AC Router. Obviously it only extended the Wireless N network.
I've bought a couple of Extender 1200's thinking they would extend my Wirless AC network using the same DHCP however I'm unsure whether these are actually Wirless AC or not? I got focused on the AC part of the product name of 11AC however I think this refers to the fact it's dual band 2.4 and 5GHz speeds? Is that correct?
In addition all they've done is created two new wifi hotspots, when all I wanted was an extention of my existing network.
Basically my set up is as follows. I have an office upstairs where my PC is, and I have an nVidia Shield downstairs which can stream games from my PC onto my TV. Now, the D-Link DIR-868L Router is next to my PC and the wifi isn't great in my lounge, that's why I wanted to use the extenders. However whereas my D-Link Router DHCP range is 192.168.100.xxx, the new Extender 1200's have a DHCP range of 192.168.1.xxx.  As such my nVidia Shield is essentially on a different network and can't detect my PC. Can anyone help me set this up correctly please (if it's even possible). All I want is my nVidia Shield in the lounge to detect my PC in my office.
Many thanks
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Extender 1200 settings confusion
Hi madwedge,
Welcome and thanks for posting. Did you get this sorted yet? If not take a look through the Dual-Band Wi-Fi Extender 600 FAQs and let us know how you get on.
Cheers
David
