Richarddixon
Message 1 of 5
BT Extender 200 Problems
I've had an extender fitted for a month or without many problems, just the odd drop out and that was it.
In the last week I either get no data or the red light signifying low speed. I can't work out why it should suddenly and consistently get worse.
Our house was completely rewired a few months back so the wiring should all be sound, could it be something that is being plugged in somewhere?
Anyone got any ideas?
4 REPLIES 4
Richarddixon
Message 2 of 5
Re: BT Extender 200 Problems
I am grtting desparate!
Message 3 of 5
Make sure that the adaptors are not plugged into a double socket with either a TV or your PC.
You could also try a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds.
Richarddixon
Message 4 of 5
Hmm, interesting, it is infact plugged into a double socket with a tv, but it worked ok before?
I'll try putting into a different socket, the TV that is.
Message 5 of 5
you could also try a reset of the extender
