honeybee1
Message 1 of 16
BT FON in France
Hi, hope someone can assist please!
I have BT broadband and BT mobile contract for my Android phone. I'm going to France shortly and can get most of the internet access I need via my mobile, which is generally pretty good 4G but sometimes it would be easier to use my laptop. I've looked for the nearest  FON hotspot to the French address and think it's perhaps 100yards away.
Someone has suggested to me that I might be able to buy a booster to improve the signal so I could use the laptop. Does anyone know what/where I could buy this please?
Alternatively, I've heard of the phone being used as a mobile hotspot. Does anyone know if this would work on an Android phone and how I would set this up please?
Sorry, I'm not very technical, so answers in simple steps would be appreciated please!  TIA
15 REPLIES 15
StewM
Distinguished Guru
Message 2 of 16
Re: BT FON in France
Hi @honeybee1 , the most reliable would be creating a hot spot with your phone. What phone do you have?
Stew
licquorice
Message 3 of 16
I wouldn't rely on being able to access the Fon hotspot, always very iffy in my experience.
honeybee1
Message 4 of 16
Hi Stew, it's a Nokia 3.1.
honeybee1
Message 5 of 16
Ok. Thanks for your experience.
honeybee1
Message 6 of 16
Hi Liquorice, thanks for your experience.
StewM
Distinguished Guru
Message 7 of 16
Try this:
Use phone as modem - Nokia 3.1
  1. Swipe up.
  2. Select Settings.
  3. Select Network & Internet.
  4. Select Hotspot & tethering.
  5. Select Wi-Fi hotspot.
  6. Select Set up Wi-Fi hotspot.
  7. Enter a Wi-Fi hotspot password of at least 8 characters and select SAVE. Wi-Fi hotspot password.
  8. Turn Wi-Fi hotspot on.
    Stew
honeybee1
Message 8 of 16
Hi Stew,
Yes, done that now. Showing Hotspot on, 0 devices connected, so guess that's the next step.
StewM
Distinguished Guru
Message 9 of 16
Try connection something to your phone to check it works. Don’t forget to turn it off when you don’t need it.
Stew
honeybee1
Message 10 of 16
I've gone into my laptop and under internet settings have disconnected wifi box, then clicked on mobile hotspot. It's still showing 0 devices connected on the phone. I've tried turring wi-fi hotspot off and on again on the phone, but no joy.
Any ideas please?
