I have just had BT FTTP installed, and run a home server which is to far from my router to hardwire. IS anybody able to recommend suitable Powerline Adapaters to get the most out of the suggested 900MBPS and 110MBPS speeds ?
Thanks.
You are unlikely to find any that will give you that sort of speed guaranteed.
You could try these https://shop.bt.com/products/bt-broadband-extender-flex-1000-kit-080219-BB4X.html
The speeds are very idealistic (my real world testing got typically between 150-300mbps), I had the TP AV1300 powerline adapters and the speeds varied throughout the day. It's worth bearing in mind that household appliances can cause issues and disrupt the overall throughput. Dishwashers/washing machines can be common culprits, it typically didnt stop transfers - just the throughput throttled down and the latency usually went up.
In the end, I decided to put cat6 cabling in my home to all the places I needed it and just removed the powerline adapters completely. I appreciate that's not always possible for everyone, but worth thinking about.
