I have a BT Business Hub 5 and recently enabled the BT-Guest-WiFi option. This works fine but I want to change the name to something related to my business name. Is it possible to configure the name somewhere in the hub manager? I have looked but the only setting seems to simply toggle the public WiFi on or off.
thanks
Welcome to the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
Hi @Dr_Jazz,
Welcome to the Community.
As mentioned, this should really be in the BT Business Forum.
But to save you the trouble, I have experience with the Guest Wi-fi for business and there is no way to change the SSID from BT_Guest_Wi-Fi.
Presumably, as this service is to also advertise BT’s services. And even if you could change it, the login page that appears is BT branded.
I recommend you invest in some enterprise/prosumer equipment to run your guest network.
